Check the AE101 wiring diagram at club4ag
To me it looks like there are 4 VSVs for the engine.
1 - VVT, obvious
2 - A/C idle up, wired to ISC pin (black-white wire) and IG 12V
3 - Electrical load idle up, wired to ELE2 pin (black wire) and IG 12V
4 - Parge? VSV, wired to IPV pin (blue - white wire) and IG 12V
It may be any of the above, though I'd say A/C idle up is the most likely candidate.
Also are you sure the vacuum tube heads to the fuel rail, or does it go to a port on the fuel pressure regulator?
Hen
EDIT - Of the 2 wires coming out of it, one should go to the ECU and one should go to ignition 12V as described above.
