http://forums.toymods.org.au/index.php?t=msg&th=67477
Water Temp Sensors.
I have the xls file at home if its not there.
Air Temp I'd hazard a guess its similar to 7M stuff.
The ECU should throw a code if they are out of spec.
 1JZGTE  air/temp sensor resistance curves
				OK, I would like (ideally) the temp / resistance curves for the IAT (air temp sensor), and ECU water temp sensor.
I have the voltage / pressure curve for the MAP sensor so that is OK.
Thanks in advance. When I get some more time I will diagnose the exact problem and start a new post...
 Re: 1JZGTE  air/temp sensor resistance curves
Water Temp Sensors.
				you have mail
