Results 1 to 11 of 11
Thread: Removing injectors
    working hard Backyard Mechanic
    Default Removing injectors
    Hey guys nobby question here i am just wondering if you have to take the intake plenum and t/b to take out the injectors on my 4agze also in order to this does the hole fuel rail come out also just to make sure if i am going about this right
    Default Re: Removing injectors
    yes you have to take the whole fuel rail off. do it in this order
    1. clean your engine with degreaser then hose off and dry (or take steps to keep it all clean)
    2. unlpug your fuel pump/ relay/fuse or whatever and turn the car over with the pump not running (this gets rid of the pressure in the system and you wont spray fuel all over the place)
    3. loosen fuel rail bolts
    4. twist injectors a bit to loosen them up
    5. remove fuel rail, watching where all the O rings fall so you can find them
    6. remove injectors, try not to drop dirt down the injector holes.
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    thanks alot i got them out today and cleaned them,
    but car still chugs like it did with dirty ones ffs
    reece12, how did you clean your injectors?
    cheers Chuck.
    took it to a auto parts place to get sonic bathed etc
    i didnt use methol or a brush if thats what your thinking LOL
    cost me 15$ injector whats the normal price for this ?
    $15.00 per injector to clean is pretty good value.
    cheers Chuck.
    VZ engine series FTW! Grease Monkey Timma's Avatar
    May 2006
    Theres some decent ultrasonic cleaners on ebay. http://search.ebay.com.au/search/sea...sonic+cleaners I picked one up for work. Think the unit i got is made by unisonics, but that was ages ago. Its definatly paid for itself, with the amount of cycles it has done. Only advise I can tell is that you should get big litrage capacity for larger stuff.
    vzv21 camry 2vzfe v6 - aka mr burble or white one
    Timma, whats the process ect for doing it? just follow directions and dump the injectors in?? they have a few on ebay for sweet FA! would be cheaper to buy one and do it my self then get a mechanic to do it!
    Hints tips directions?? Yu are more then welcome to PM me instead if you dont wanna hijack
    Cheers!
    Malicious
    May 2006
    I haven't actually done it before but i plan to in the near future. I say follow the process & pull the fuel rail out and pop em in. Might have to give em a bit of a clean with a new toothbrush first. Make sure you dont get anything foreign inside them and dry em out fully. Maybe blow em out with some compressed air after get the left over water out. Let us know if you go ahead n do it. Cheers
    May 2006
    aww yeah forgot clean ya fuel rail when its out 2 and put some rubber grease on the injectors when you put them back in 2
  1. Where to get BIG top-feed injectors?
    By Norbie in forum Tech and Conversions
    Last Post: 17-06-2006, 04:22 PM
  2. Removing / Inspecting valve springs without removing the head - is it possible?
    Last Post: 16-06-2006, 01:58 AM
  3. Aftermarket engine management and injectors
    Last Post: 14-05-2006, 01:05 PM
  4. mechanical specs for 4agze injectors
    Last Post: 04-01-2006, 12:05 AM
