Results 16 to 22 of 22
Thread: Overheating ta22
    Obama Family Friendly Backyard Mechanic 74sLeeka's Avatar
    May 2006
    Default Re: Overheating ta22
    leaving to get a *free * pressure test rite now from mr. radiator in blackburn
    Rides:
    1974 TA22 Celica 2T-GEU - Gone
    1989 ST162R Celica 3S-GE - Stock Daily
    2005 Honda CB250 - New Toy
    Can I Fondle Your Grease Monkey
    If u suspect its your heater tap, disconnect the heater coolant hose at the back of the block on the passenger side and plug it up with a rubber cap (you can buy from repco or supercheap). That way you can tell whether or not its ur heater.
    Run a bypass between your 2 heater hoses till you get the new tap. If it still overheats, then you need to dig deeper, but at least you wont be loosing coolant and killing your carpet.
    May 2006
    radiator dudes are replacing therostat and bypassing it now.. but wat doesnt make sense to me is..
    i was told the pipe i took a photo of is the heater tap (correct me if im wrong) and if that is blocked or leakin.. how the hell is my passenger carpet wet ? i was told by the radiator pro that its wet coz the heater itself is leakin !
    doesnt make sense how it can be the tap, and the water gets to the carpet..
    Rides:
    the pipe you took a photo of isnt a tap of any sort. IIRC the heater tap for the TA22 is inside the cabin. What you took a photo of appears to be a joiner. Probably somebody with a split hose, had a bit of copper tube and some clamps, and was too stingy to buy a new hose...
    May 2006
    that makes more sense.. coz i tried to explain that joiner hose to shelldrake on msn.. he said thats the heater tap.. must of been my description
    Rides:
    The heater tap is usally hidden under a grey plastic cover... Just two screws and it will come off and you'll see if there is a problem
  1. TA22 Facts and specifications
    By TheToyman75 in forum Tech and Conversions
    Last Post: 23-12-2021, 10:15 AM
  2. Building an Australian RA21 (18RG + TA22)
    By ace in forum Tech and Conversions
    Last Post: 04-07-2006, 09:09 AM
  3. Cooling Systems - Overheating Problems.
  4. ma61 diff in a ta22?
    By weapon x in forum Tech and Conversions
    Last Post: 19-04-2006, 11:25 PM
