harmonic balancer.. the only way to check is to get up close with it and check condition of the rubber part.
Bear in mind that the harmonic balancer is on the same thing as the flywheel, so the machining of the flywheel could well be the cause, resulting in increased vibrations.
Generally the throw-out bearing noise goes away if you put the clutch in, so you can count that one out.
