Results 1 to 3 of 3
Thread: wierd sounds of a gen 2 ported shroud GTX3071R
    ethanol sniffing Backyard Mechanic adamaw11's Avatar
    Default wierd sounds of a gen 2 ported shroud GTX3071R
    I've just upgraded my turbo, was previously running a chinese copy 2871, never had a ballbearing turbo before.
    So now I have a Kinugawa Gen2 3071R, with ported shroud.
    So it squeals a lot when off boost, just light throttle, even coming off idle it can be heard, it doesn't sound like a vacuume leak, just this high pitch squeal that gradually increases with more throttle and revs. A squeal or whistle, whatever you'd call it, but it's fairly loud.
    Also, when turning the car off, it sounds like the turbo keeps spinning for quite a while, not just a smooth spinning sound, almost like a chugging sound, almost like the wheels of a skateboard or something, maybe this is just the normal sound for a larger ballbearing turbo?
    Maybe the ported antisurge shroud also affects how it sounds when it's spinning down?
    It is a brand new turbo, so maybe the bearings or something still needs to bed in?
    The turbo seems to do every thing right now the wastegate is not making it overboost, and spools up pretty nicely around 4k plus on the blacktop 20v.
    I'm just hoping all these wierd sounds are just normal for a modern aftermarket 3071, and not something wrong with the bearings.
    Can anyone comment on their own experiences with gen 2 ball bearing turbos?
    Default Re: wierd sounds of a gen 2 ported shroud GTX3071R
    Just to update this, the sounds are all still there just the same. I think I'll ignore the sounds and just enjoy what the turbo delivers, and let it idle for a while before turning it off, in case it helps.
    But to comment on how the 3071 is on the 20v, I'm really happy with it. No worries about it being too laggy or anything. At 3k rpm it still pulls harder than NA, and by 4k rpm there's some usable grunt there. Definitely a good choice of turbo for a 20v 4age, wouldn't say it's too big at all if you want power in the mid to high revs.
    Jul 2007
    I have a legit Garrett GTX3071R on my 9A, with the anti surge housing. It doesnt squeal off boost, but it does squeal if you go slowly ease off from full throttle to part throttle when the turbo is boosting hard, which I assume is air bypassing the anti surge housing to correct for the fact you just fucked the volumetric flow rate but it is still pumping high pressure (therefore pushing you toward the surge line)
    you can hear it pretty well here (watch exit of fish hook about 3:48)
    https://youtu.be/UKpwlyPD2jM?list=PL...C6-Kzn-z&t=226
    And yeah you can definitely hear it spooling down for a good 10-20 seconds after switching the car off. It sounds like roller skate bearings etc
  1. Ma70 fan shroud
    By crownman in forum Cars and Parts Wanted
    Last Post: 02-03-2018, 09:22 AM
  2. Ported 2JZ / Ported 1FZ comparison
    By MS-75 in forum Tech and Conversions
    Last Post: 18-10-2017, 11:44 PM
  3. Which Electric Fan + Shroud to Clear JZA70 Engine.
    By Z2TT in forum Tech and Conversions
    Last Post: 12-12-2012, 01:54 AM
