Results 1 to 9 of 9
Thread: using angle grinder on inlet cam of 3sfe for better fuel economy
    Aug 2012
    Default using angle grinder on inlet cam of 3sfe for better fuel economy
    Sounds wack but were I live the 1.5 tonne family townace spends most of its time
    going up hills, down hills and no more than 40-60kn hr yet torque peaks at 4200rpm
    but we never get over 2000rpm anywhere. Fuel economy is completely like politicians.
    My idea was to put in a diff ratio to raise rpm nearer the torque curve as its an auto
    with overdrive that rarely sees overdrive at all. We dont use the freeway and dont
    race anyone anywhere so the diff is one scenario but....
    The 3sge has got to have the worse economy of any toyota engine for its torque
    and power ratings for its capacity.
    I looked at tri-flow cams (unequal independent inlet duration grind) which supposedly
    increases torque everywhere on multivalve engines like the KA24de and other 16v heads
    https://www.coltcams.com/html/tri_fl...ogy/index.html
    Really hoping thats my ticket eventually however since these engines are so cheap
    was thinking of grinding one of the lobes off completely from the inlet camshaft
    so I would have only one of these small inlet valves creating a swirl effect with high
    velocity in the chamber therefore more torque like the Buick nail heads of the 1950s.
    Sure I wouldnt get the hp as I did before but this engine never sees anything close
    to the redline in anyway let alone get to its torque sweet spot area.
    I was also thinking of using a spacer for the oxygen sensor so it detects less O2
    and leans out the mixture as these old engines in Japan seem to run richer than
    in Australia for some reason and wear out rings in jp engines unlike Aussie versions.
    Am I off the wall in this or does anyone think I have a chance to get the torque
    down lower and fatter by just using one small inlet valve at high velocity?
    This is before I go an order a Tri-flow grind for it etc.
    Apr 2019
    vic
    Default Re: using angle grinder on inlet cam of 3sfe for better fuel economy
    Have you had the auto serviced? The auto should downshift under high load, and use all of the RPMs of the engine. If the engine doesn't rev past 2000 rpm up a hill, all that fuel is turned into heat, both in the engine and the torque converter in the auto.
    Will the Auto manually change down when select low gears?
    Aug 2012
    Quote Originally Posted by Liquidhandwash View Post
    it does downshift well but gearing is surely for flat lands! I dont like downshifting manually but it helps to get the revs up
    Its the wives car so only I shift it manually, she drives like a butterfly which is fine with a toddler but it does my head in.
    just found out Bisimoto also supplies the same kind of staggered cams for non vtec builds and world records
    We are only after economy via lowering the torque sweet spot but might need to look for a 4.11 ratio from a 4wd petrol
    or 4.3 from the 4wd diesel version. Just rechecked torque is at 4400rpm!!! darn nasty but 11km L sounds good not 7km L
    Apr 2019
    vic
    If you have a look on the ID plate it will tell you what diff it has in it and you may find something else will fit. I have A 4:3 diff in a Hilux I am parting out, the Axel code is G102. The "102" is the ratio code. Most anything with a G code is interchangable, (interdependent rear ends are an exception)
    have a look here.
    http://www.dealerquickparts.net/HPFile/AXLE%20CODES.pdf
    Aug 2012
    will do thanks and just a note this car has 103k kms always serviced every 5k km.
    wa
    5sfe an option?
    Aug 2012
    Quote Originally Posted by jonathan yee View Post
    5sfe an option?
    Was my first choice but cant get any here in Japan atm, they are rare motors now.
    Im wondering if I can change from the early injectors with few jet holes to later ones from another toyota?
    Otherwise Im sourcing another a camshaft asap but not sure whether I could run an exhaust cam with
    more lift and duration to emulate the buick nailhead v8s which used the same principle
    eg.
    It became known as the "nailhead" for the unusual vertical alignment of its small-sized valves.[1] To offset the smaller-sized valves and restrictive intake- and exhaust-port diameters, the nailhead V8 family used a camshaft with greater lift and duration. The small-diameter intake runners allowed these engines to develop high torque, with many exceeding one foot-pound per cubic inch, exceptional for the time. All of the nailhead designs have a 4.75 in (121 mm) bore spacing.
    I could probably nab a beams camshaft as there are plenty of these here but need to find out the duration information for the 3sfe and the 3sge to make sure its enough lift and duration to bother.
    Otherwise will have to reground an original which is prob going to cost more than it should since
    machine work here is overpriced.
    Jan 2017
    You could run a massive tappet gap on one valve in each cylinder and see how it feels. Let the valve open late, open less, and shut early so it gives an asymmetric swirl. Take out the tappet disc so its reverse-able, or if you're keen you could grind the top off the valve stem. It will rattle like mad and destroy the cam lobe or follower or valve top eventually....
    Aug 2012
    Love those ideas, the S rattlesnake swirl head! The idea of machining the top of the every second valve is great!!!! I can get that done professionally on a spare head then put that on. Thank you!!!!
    On the same note does anyone have a wiring diagram as so far can only find the crank positioning sensor and no cam positioning sensor which could mean since its a 1996 early model its probably a dumber ecu or Im the dumb one!?
    On the Rav4 and Camry its easy to spot on the top right of the cambelt cover.
  1. Causes of Bad Fuel Economy.
    By Z2TT in forum Tech and Conversions
    Last Post: 14-08-2009, 03:25 PM
  2. 1jz fuel economy
    Last Post: 19-04-2009, 02:16 PM
  3. Fuel economy
    By winnie_man in forum Tech and Conversions
    Last Post: 26-06-2007, 10:25 AM
