Results 1 to 2 of 2
Thread: 8NR-FTS into Echo
    Aug 2011
    Default 8NR-FTS into Echo
    G'day, a friend of mine has an XP10 1.3 litre Echo from around the year 2000, and for a laugh, we got to discussing what it would take to put the engine out of a Toyota CH-R into it, the 8NR-FTS Turbo engine. So my questions are these:
    do the 2NZ-FE and the 8NR-FTS engine share the same bellhousing pattern?
    will the engine mounts be similar?
    is it all going to physically fit in the engine bay?
    will the CH-R motor destroy the gearbox from the echo? will it break driveshafts?
    how much boost can the CH-R engine run?
    what about the brakes? the echo brakes are barely adequate at the best of times, so maybe the CH-R brakes will fit?
    will a Haltech ECU run it all ok?
    Is there anything else you'd like to add? anything I haven't thought of?
    Cheers, Gab
    Apr 2019
    vic
    Default Re: 8NR-FTS into Echo
    Pretty sure that engine is direct injection, so no a Haltech ECU will not run it, unless you convert the engine to port injection. Im always a fan of motor conversions, so good luck with your project. Ive been dreaming about putting a super charged V6 camery engine in the back of a pruis.... sleepers are so much fun.
  1. Echo 2nz to 1nz conversion.
    By wa5 in forum Tech and Conversions
    Last Post: 20-04-2015, 02:32 AM
  2. Misfiring Echo
    By briigo82 in forum Tech and Conversions
    Last Post: 12-08-2011, 08:48 PM
