The bearing for that engine come in different sizes for that dummy cam. If your builder changed them out, question the measured thickness of the ones installed... Also you will have to turn the cam bearing to cover the opening of that former camshaft lubrication discharge port since the dummy cam requires fewer bearings, and the ones towards the rear will have to be rotated to close off those areas or you will have a loss of oil pressure... But you already knew that!!
