Hmm when you say it, i had to change the fronter part of the transaxel to get the 22 spline for the gearbox. I installed it like the old one were placed but maybe got it 180 degrees wrong.
Or maybe every axel is balanced on it's on and is not interchangeable without re-balancing?
Anyhow i have orded a new centerbearing so i will tear down it all to change it and will try to turn it 180 degrees and back and se if there is a difference.
What happen if the centerbearing have tension on it?![]()
Also one Thoth is that the new engine mounts/engine setup it not perfectly centered/straight so the angels of in and out is a bit of. That would also make this symptom right?
