Sounds like the booster. If you pull the vacuum hose off, do you hear air rushing in the booster? There should be a check valve in the system to maintain vacuum. Davew7
Hi Everyone,
i have had a look through the forum and have not been able to find any information on the MC conversion i have under gone.
My original one had the seal let go, so i replaced it with a newer Camry MC which bolted straight up just had to manipulate the lines to fit.
Now i am having the issue of the Brake pedal falling to half way then it because ridiculously hard and does not lock up the brakes as if it where original.
i have checked the vacuum of the booster seems to be OK and is the same as my other TA22. i have bled the brakes correctly.
any suggestions on what to look for?
Yes i have tried that and i cannot hear any air rushing out of the booster, but when the pedal is pressed i can hear air escaping from somewhere. not sure where though.
