Part number should be: 89420-24040
According to ToyoDIY, part number is exclusive to JZZ30, so not the same part no. as JZA70 or the 2JZ. Appears to be out of stock on Amayama.
As far as I understand, the difference between this one and the others (JZA70, 2JZ, etc) is in the bracket and they actually output the same (0-5v 2 bar sensor) so in theory, the JZA70 and 2JZ MAP sensors (including the boost gauge sender on vvti models) should be pretty interchangeable...
