just be verrrry careful if you are significantly compressing the spring..
what rate are your springs? sayy.. 4kg/mm ?
4cm is 160kg of force (80kg on each side) etc.... if you can hang your weight by them, you can (maybe) safely compress 4cm
if you are going to compress them a lot, do the fencing wire/many cable tie mod also![]()
good luck![]()
I should have told her so the blood stains would be less noticable.
