Results 1 to 3 of 3
Thread: 1JZGTE air/temp sensor resistance curves
    Default 1JZGTE air/temp sensor resistance curves
    OK, I would like (ideally) the temp / resistance curves for the IAT (air temp sensor), and ECU water temp sensor.
    I have the voltage / pressure curve for the MAP sensor so that is OK.
    Thanks in advance. When I get some more time I will diagnose the exact problem and start a new post...
    Default Re: 1JZGTE air/temp sensor resistance curves
    http://forums.toymods.org.au/index.php?t=msg&th=67477
    Water Temp Sensors.
    I have the xls file at home if its not there.
    Air Temp I'd hazard a guess its similar to 7M stuff.
    The ECU should throw a code if they are out of spec.
    Junior Member Backyard Mechanic ndgcpr's Avatar
    you have mail
