Page 3 of 3 FirstFirst 123
Results 31 to 34 of 34
Thread: RT142 Handling - Suggestions?
    Default Re: RT142 Handling - Suggestions?
    Quote Originally Posted by pisso001
    Yeah ive got an adjustable Kmac sway bar in the rear works pretty well.. Need to learn how to adjust it properly though.. Gonna get one for the front soon too...
    How do the 6kg springs feel? Ive decided to keep this car for street only and maybe the odd skid pan day so i wont something comfortable but still handle well.. Its got bilstien shocks in it so it handles nice. Just dont know about spring rates yet...
    Thanks,
    Chris.
    If you want to drift i would go 9 or 10 in the front of a rt142, 6 is good for the street.
    Jun 2007
    south australia (adelaide)
    How did you set up the double sway bar.. Im interested in doing this.. Is it dodgy and does it work well?
    thanks,
    Chris.
    i cut off the ring ends of the 2nd swaybar, then used 4 extra swaybar mounts (The ones with bolt holes either side-only on the irs toyotas, live axles have the shitty ones that wont work for this) and high tensile bolts to attach it to the original.
    It is fairly dodge, and the only good place i could find to put the mounts ended up rubbing on the axles. But since then i've put some spacers in where the original swaybar is attached to the control arm which stopped them rubbing. I know it sounds difficult but once you look under the car and start doing it everything becomes easier to understand.
    do a google search for "double swaybar" - theres one or two handy articles on how to do it
    May 2007
    N.S.W
    this is a bit out of the suspenion question but does anyone know what type of manual
    gearbox is the advante its a 86 model.
    I am wrecking a advante so if u want parts make an offer just call
    on 0423 689 587.
    Junior Member Backyard Mechanic pisso001's Avatar
    I think they have a w55 in them.. Ill buy your bell housing off you.. Probably some other parts too..
  1. GA70 diff compatibility with RT142
    Last Post: 20-03-2006, 09:05 PM
  2. rt142 independent rear = ra65/sa63 celica
    By Mattrt142 in forum Tech and Conversions
    Last Post: 26-02-2006, 12:48 PM
  3. 4AGZE Intercooler and exhaust suggestions?
    By DavisJD in forum Tech and Conversions
    Last Post: 07-02-2006, 05:20 PM
  4. Rt142 rear springs etc.
    Last Post: 31-12-2005, 02:57 AM
