Results 16 to 18 of 18
Thread: my SC14 fitting guide
    Learner / modder / Backyard Mechanic PrettyCoolWagon's Avatar
    Aug 2009
    Thumbs up Re: my SC14 fitting guide
    Quote Originally Posted by 86Slider View Post
    For anyone not using a AW11 block, here is what i done a little different to the above instructions.
    Firstly, when I mounted the sc14 on the lower bracket, even with the spacer washer in place, the pulley was still sitting too far back for the belt to line up. So with a little guidance from Adsport, I grinned into the lower bracket, about 4mm, to allow the charger to move further forward.
    This meant that there was no need to fully remove the front bottom bolt hole of the suction pipe.
    I also made a small bracket to hold the dipstick in place.
    Finished result looks like this;
    Good to see a couple of different ways to do it.
    Aug 2009
    Default Re: my SC14 fitting guide
    deleted post - misread SC14 vs. SC12
    Please see below
    Last edited by PrettyCoolWagon; 06-01-2011 at 12:17 AM. Reason: Put in incorrect info - ammended post below
    Aug 2009
    Quote Originally Posted by jdm86gtz View Post
    Is there any write up of how to fit SC14 with N/A manifold in RWD chassis (AE86)?
    Top o' the mornin' to ya mate!
    I know you asked this some time ago but if you haven't found your answers there is one for a SC12 with N/A manifold. You could combine the info from both write ups.
    I'm sure between them there's enough info to lay your hands on the tools & work through it.
    Here, try this link:
    http://www.aeu86.org/viewtopic/ae86/...r=asc/start=75
  1. Sam-Q's 20V RWD Cooling System Guide
    By Sam_Q in forum Engine & Driveline Conversions
    Last Post: 27-03-2007, 06:08 AM
  2. Sc14 Supercharger
    By vin91 in forum Tech and Conversions
    Last Post: 22-06-2006, 02:24 PM
  3. Replies: 24
    Last Post: 18-04-2006, 02:42 PM
  4. Strange fitting on Vacume line ( 4agze)
    By clean82 in forum Tech and Conversions
    Last Post: 08-02-2006, 10:43 AM
