This ^^^ does not sound right. I don't have specs for your car but if it uses an injector resistor pack, then it must have low-res injectors. These are usually 2-3 Ohms. The resistor pack puts extra resistance in series with each injector to bring the total resistance up to something like a high-res injector. This means I would expect to measure at least 5 or 6 Ohms across the resistor pack, meaured from the input wire to each of the output wires.
Measuring pin to pin on the output side should give double the resistance i.e. maybe 10-12 Ohms. Please check and confirm ... make sure your meter is on the right scale.
Cheers... jondee86
