1 Remove speed signal from ECU
2 Put ECU to neutral/parking range (NSW to ground)
This will eliminate DTC42
Note this trick only works on these old ecus like yours
Newer ECUs (JZS16x,JZX11x,etc) will have different maps for N and D range, and in D range limp mode will be triggered b/c of the lack of solenoids, in/out speed sensors etc
p/s 1k Ohm, 0.25Wt from fpc to +b will cure dtc78
