Page 1 of 8 123 ... LastLast
Results 1 to 15 of 108
Thread: 1UZ into MX22, more pics now.
    tasmania
    Default 1UZ into MX22, more pics now.
    i wasn't gonna start this thread until i had a good load of pics of progress, but i thought it might help me to gather info and tips if someone see's something that i could change or do better with.
    At this stage the motor is in, but the position needs to be tweaked a little to gain some room for the thermo's and exhaust, and steering, and the sump.
    so, what i've got is:
    UCF10/11 1UZ-FE(that's what was here and cheap)
    front sump was changed to mid sump
    custom exhaust manifolds being made in stainless
    hilux/pug front brake upgrade
    st141 rear disc brakes on the way
    e diff changed to f diff
    UZS131 auto(slipyoke)
    custom mounts
    custom gearbox crossmember
    UZS131 ecu(i'm gonna run tiptronic controller)
    mx83 tailshaft yoke to be fitted to standard mx22 tailshaft
    vb commonwhore rack(might not be suitable as i didn't know about bumpsteer, ackerman angle etc)
    i'll think of the rest if/when i can.
    any helpful hints and advice welcome
    i'll be taking the motor out this weekend i reckon, so i might take some pics then, and i'll put the ones i have up soon.
    cheers, joe
    beer me!
    Default Re: 1UZ into MX22
    I'm looking forward to seeing some pics of this. I'd be rather interested in putting a 1UZ into a MX23 at some stage.
    tasmania
    here's a couple of pics, nothing special. i'll be taking the engine out so i can modify the mounts i made. i'll also try to get some more of the exhaust manifold's done while it's out.
    beer me!
    Very cool.
    It is certainly tight but looks do-able.
    Good luck with it.
    Nice work Joe !
    It will be an aweosme combo once its done
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    tasmania
    yeah very tight. the biggest pain is the exhaust. it's gonna be an arse to get in there, and to get the nuts done up, not to mention access to the engine mounts
    anyways, i'm moving the mounts forward a bit so you can get at them from under the front
    i've removed all of the accessories from it bar the alternator, so that gives me a bit more room at the front of the car for thermo's, and also makes it easier to change the timing belt. if anyone want's more details on the alternator tensioner rig let me know, but i should have some pics this weekend any way.
    beer me!
    Good work.
    Cambelt1 dropped one in an MX13. Even with the engine moved over to the passenger side a bit, there wasn't enough room for the smaller manual steering box. The Commodore rack might work, but you might have some luck with something like an AE86 or RA65 rack. We thought that hanging the rack off a crossmember that bolted to where the steering box and idler arm bolt to the sub frame might be the go.
    Gearbox Xmember is easy.
    There isn't much room for a decent exhaust - I suspect you'll be limited to the standard Crown log manifolds. Even then, you'll need to modify the driver's side to clear the connection between column and rack.
    Also with regard to radiator, not sure if there is a 4 core the same width as an MX22 one.
    tasmania
    thanks GT.
    i'm making custom exhaust manifolds with 1 1/4" S/S 90 degree elbows, they're only about 70mm high
    yeah this rack sits in the recess of the mid sump, mounts will be welded to the corners of the xmember. i'm using what i believe are tr magna ball joints one it, and the control rods had to be chopped about 50mm each and extra thread added. this rack has an extra shaft with two uni joints on it, should help me to put it in the appropriate place.
    gearbox xmember was SOOO EASY! a bit of RHS with a large hole in the top worked perfectly. although i have to move the engine back 20mm so this will have to be tweaked where it bolts to the car.
    beer me!
    tasmania
    this is the auto xmember i made. if anyone wants dimensions pm me.
    before...
    after. i haven't welded them back on yet.
    the mounts i made
    on the motor, with part of the exhaust that i'm making.
    beer me!
    tasmania
    the exhaust "clearance" with the engine back in. i can lift the engine up to give a bit mor room, but it think i'll have to persuade the rails.
    beer me!
    tasmania
    by the way, where does the dipstick go through the head on crowns? this sump hasn't got provisions for one, so i thought there must be somewhere i can upt it in the head instead of trying to weld to the sump.
    beer me!
    Default Re: 1UZ into MX22, more pics now.
    Awesome work dude, looks like your making some great progress.
    Quote Originally Posted by joecoolmk2
    Will take pics 4 you.
    Crown Dipstick
    tasmania
    cool, thanks cruzida. god those manifolds suck! i'll just go and see if i have a blank boss there to drill....
    beer me!
  1. 1UZ bottom end bits
    By mrshin in forum Tech and Conversions
    Last Post: 25-07-2006, 08:58 PM
  2. 1uz Ms65. I Need Some Advise
    By AZZTOY in forum Tech and Conversions
    Last Post: 19-03-2006, 04:43 PM
  3. MX22 and MX13 conversion
    By cyprus73 in forum Tech and Conversions
    Last Post: 13-02-2006, 10:51 AM
  4. 1UZ into RA65 - Drift car.
    By nihilism in forum Tech and Conversions
    Last Post: 08-02-2006, 11:16 AM
