Depends on whether the 16v gearbox has front and rear starter locations if so all good.
Hi all,
I currently have a AE92 with a 20v 4age, does anybody know if the 16v gearbox fits the 20v engine?
as far as i know the blocks are the same and should fit but i just wanted to check.
just finished fitting the new gearbox and thought i would post to help people in the future.
so the things i found that were different were-
The starter motor on the 16v is on the front off the motor behind the exhaust manifold (if looking at the motor in a FWD configuration) were on the 20v it was located on the back.(will not effect the swap at all just thought i would share it).
one other this is the revers light switch has a different connector on it that plugs into the wiring loom, you could either buy the correct one or just crimp some new connectors on to it.
