I have a sneaking suspicion that these may be KE70 brakes - which would probably make sense as they are likely to be KE70 coilovers from AJPS.
Can anyone confirm?
As you can tell I'm hardly familiar with Celicas just yet.
I've got a set of coilovers with strut tops with a slightly smaller PCD. I can't tell what the brakes are off and what the coilovers are from. If anyone has any ideas that'd be great? I'm working out whether I try and source some stock front struts for now or whether I space these coilovers an inch or so for more travel and work out what brake pads I need!
Here are some pictures while I've been tidying it up.
RA23 Celica - 18RG, 40mm Webers, 92mm Arias pistons, 11.1:1 C/R, 15x7 SSRs.
910 Bluebird - FJ20ET, IRS 4.4 LSD, 251kW on E85
910 Bluebird - RB25 Track Hack
Can anyone confirm?
XT130 maybe?
Hmm alright!
Measure the disks and look up on dba catalouge.
So turns out these are the stock 225mm TA22 brakes. That explains the smaller strut top PCD as well! Had to get the pads matched up to find out what they were. Suprised no-one here was familiar?
So now I'm going to have to chase down the stock RA23 brake calipers, will buy some replacement rotors and put my longer Landcruiser studs in so I'll be a bit cheerier about the stud length using alloy wheel nuts.
Look a lot like ra40 caliper but the ra40 rotor is bigger.
