If the mixture screw is out 5 turns to get it to run then the primary idle jet is too small. Idle mixture screw should be somewhere between 3/4 and 1 1/2 turns out when you have the correct size idle jet. Check that the secondary butterfly is fully closed when the throttle is at idle position. There is an adjustable stopper for the secondary throttle shaft that screws in from underneath. if the secondary butterfly is slightly open you will have trouble getting it to idle smoothly.
