Originally Posted by
Daddio
1UZ-FE MAF is same as 7M-GTE (electronics wise)...its not the MAF electronics that is paired to the injector size, its the MAF body...on the 7M-GTE the 1UZ-fe MAF body (with either 1UZ-fe or 7M-GTE electronics) is sized pretty well for 550cc injectors on a 3L (its a common 'old school' mod for more boost/airflow). Basically the larger body allows more air flow with the same signal from the Karman Vortex sensor, which "compensates" for the bigger injectors. The injector control is in the ECU, so you just need a MAF body that flows around 25% more air than the original to keep fuelling in balance. You might ne able to achieve this with a 1UZ-fe body and fiddling with the bleed screw...
