VIN No: MA700107892
Engine No: 7M0200089
142,000kms on the body (Engine Rebuilt at 118,000kms)
Engine Details:
Orginal 7MGTE
Orginal CT26-E
Engine machined and fitted with all new plugs, rings and bearings etc.
Eagle Rods with ARP Rod Bolts
ARP Head Studs
ARP Main Studs
HKS Metal Headgasket 1.2mm Bead Type
Driftmotion Upgraded Oil Pump with AZ Performance Oil Pump Pipe
New Waterpump
New gaskets and a lot of hoses changed to softlines.
Head reconditioned with 3 angle grind and clearances set.
Titanium 3" Exhaust
(Please refer to photo of spreadsheet for more details)
Transmission:
R154 5 Speed Manual
Action 6 puck ceramic/metallic sprung clutch
New Pressure Plate
Marlin Crawler Urethane Shifter Bushes
Marlin Crawler Shifter Socket
ARP Flywheel Bolts
New Bosch Starter Motor
New Clutch Master Cylinder
New Clutch Slave Cyclinder
New Speedo Cable
To much to list about this car. Also comes with two boxes full of original & spare parts.
Mechanically it runs like a dream and as you could imagine the owner has spent a fair bit of money ensuring its reliability.
Bad points are the car is not immaculate, as you can imagine it is nearly a 30yr old car, has paint fade on the roof, swirls, scratches and scuffs. Also the leather on the driver’s seat and center console has cracked. Tyres will also need to be replaced.
Car will also come without reg & rwc. It is still drivable and can be driven with a permit.
I have a ton of paperwork here, receipts, invoices, documents, emails etc.
