Results 1 to 2 of 2
Thread: TA22 Factory Oil - Amp Gauge wiring
    Dec 2009
    Default TA22 Factory Oil - Amp Gauge wiring
    Hi - Need help with wiring the factory amp gauge in TA22 to a vehicle that never had one - no problem with the Oil Gauge and light its sorted.
    I want to know the best place to run the + positive wire from for the Ammeter. Does it have to be switched from the ignition?
    Can it be wired from
    1. Cig lighter
    2. or from the fuse box (which wire)
    3. run a whole new wire from Alternator or Battery. (in the factory manual the wire looks like it comes from the Battery + fuesable link)
    Aug 2009
    Default Re: TA22 Factory Oil - Amp Gauge wiring
    Here is a link with a bit of info about installing. Just remember you need a fuse in the amp gauge wire because it is the line for main power supply, for gauge to work properly full current used must pass through gauge.
    Link: http://www.toymods.org.au/forums/thr...-%282T%29-TA22
    Cheers.
  1. Help with OEM boost gauge wiring
    By Gibbon in forum Tech and Conversions
    Last Post: 11-12-2013, 10:02 AM
  2. MX73 Gauge cluster wiring diagram
    By toycentury in forum Tech and Conversions
    Last Post: 06-07-2012, 11:55 AM
  3. Air/ Fuel gauge wiring for ST185
    By chrisGT4 in forum Tech and Conversions
    Last Post: 17-04-2009, 10:07 AM
  4. HKS electronic gauge wiring?
    By Endless in forum Tech and Conversions
    Last Post: 15-03-2007, 07:59 PM
  5. Wiring issue? - temp gauge stuck on max
    Last Post: 18-02-2006, 03:49 PM
