Results 1 to 8 of 8
Thread: 1998 Caldina GT-T (384awkw) - NSW $17.5k
    Default 1998 Caldina GT-T (384awkw) - NSW $17.5k
    Don't need to sell, don't really want to sell but if someone was to pay the asking price I'd let it go. Reality is the car has done 6,000km in the last 3 years since being fully rebuilt so would rather see someone who has the time and passion to enjoy it than see it parked up.
    Specs:
    3sgte Fully Rebuilt
    Carillo Rods (Rated at 1200hp)
    JE 9:1 Comp Pistons
    Billet Main Caps
    ARP Main & Head Studs
    HKS Stopper Head Gasket
    Brian Crower 0.5mm Oversize Valves
    Jun Valve Springs
    HKS Cam Gear
    Kelford 262 Cams on Inlet & Exhaust
    Lightly ported/cleaned up head
    Setup completely balance with OS Giken Twin Plate Racing Clutch
    Garret GTX3076r with 0.82 Rear Housing
    6 Boost Manifold
    Generic Intercooler with custom piping retaining the factory airbox.
    Ecu
    Haltech PS1000 with IQ3 Race dash
    Gearbox
    Standard but rebuilt to factory specs 6000kms ago
    Rear Diff
    Cusco 2 way LSD
    Wheels
    17 x 8 Enkei RC-T4 (+35 Offset)
    Brakes
    Front 330mm Rotors with K-Sport 8 Piston
    Rear 304mm Rotors with K-Sport 4 piston calipers
    Pads Ferodo DS2500 + Spare set of Brand New K-Sport pads (Good for using if waiting for replacement pads)
    RBF600 Fluid
    Suspension
    Aragosta Adjustable Coilovers (Both height & Dampers) with 10kg front springs & 6kg or 7kg springs can't remember off the top of my head. Cusco Tops on the front Struts They run inverted dampers cost around $4500 to replace.
    Also have a set of Tein HR coilovers which came with the car initially. Will be included and can be slotted into the car if you wanted to get the aragosta sent off to be rebuilt.
    Fuel System:
    ID2000cc Injectors
    Zeitronic Flex Fuel Sensor & Digitial Gauge
    Custom Surge Tank with 2 x Bosch 044
    Aeromotive Stealth 340 used as a lift pump
    The car is completely tuned as a flex vehicle so can run low boost (21psi) on 98ron, Eflex or United E85. Otherwise flick the boost up to 28psi on Elfex or United E85 and it will make over 380awkw. Mechanically the car has 6000km on it. The Suspension and Brakes would have maybe 15,000km.
    Cons -
    Aircon has been regassed with dye to find the leak in the System, so far after 2-3 months it hasn't leaked.
    Need to find someone who does upgraded engine mounts and swap them over. The brand new factory ones I put in during the build are not stiff enough. Will probably due this myself money permitting early in the new year. Terry @ Road and Track does upgraded mounts so will source a set from him once a few things settle down.
    Not engineered but does have rego until December 2016
    Full details of the build and picture below.
    http://www.toymods.org.au/forums/thr...T-got-traction
    If in doubt power out
    Jul 2007
    Default Re: 1998 Caldina GT-T (384awkw) - NSW $17.5k
    fuq that's cheap...
    Buy my car, reasonable offers will be considered.
    Bump $15k
    Pros
    New engine and diff bush installed
    Just had major service
    Rego to december 2017
    Cons
    Needs new aircon condenser plus regas
    Bargain bargain bargain bargain
    EP82 Starlet GT - [URL="http://www.toymods.org.au/forums/forum-members-rides/71090-stus-ep82-starlet-gt.html"[/URL] SOLD
    EP82 Starlet GT V2.0 - http://www.toymods.org.au/forums/sho...98#post1514198 SOLD
    The IS400, GXE10 with 1UZ - http://www.toymods.org.au/forums/thr...8-StuC-s-IS400
    And it's gone............
    Sad day. Did a Toymods member grab it Jono?
    Oct 2013
    essex
    if you still have this i dont suppose you fancy selling the teins if they are in good condition
