Results 1 to 4 of 4
Thread: 1uz into lx90 wont rev properly
    Apr 2008
    Default 1uz into lx90 wont rev properly
    Hi all
    i have a lx90 and i have fitted a 1uz into it.
    I have an issue that I assume is electrical. Start the car and it will idle fine. When you try to rev it, it revs up to about 1600 rpm then dies and comes back on at 1100 rpm. It will do this in a pattern. Also if i press down further on the accelerator pedal it will rev as little higher like 1800 and come back on a 1300, this is as high as it will go. the check light is not on.
    I have cleaned the throttle body
    tried other ECU's
    tried other ignitors
    tried other air flow meters
    i have wired up everything from scratch again thinking i made a mistake
    i have unplugged the ignitors while running to see if its running on one bank, either one causes it to stall right away
    no joy
    when i first got it running i took it for a drive before it idled at all, and it reved properly no dramas at all.
    anyone else seen this problem?
    Feb 2007
    Timaru
    Default Re: 1uz into lx90 wont rev properly
    Incorrect TPS wiring or bad TPS.
    Unplug the TPS and see if it makes the problem go away.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
    Apr 2008
    okay I unplugged the TPS, exactly the same.
    I swapped the entire throttle body from my LS400, exactly the same
    Checking the wiring now.
    Apr 2008
    DX20VT you were spot on,
    I had earthed a wire that I should not have,
    Car is usable. Thank you so much for your help !
  1. Help, clutch wont disengage properly
    By nuk1ear in forum Tech and Conversions
    Last Post: 02-03-2011, 10:15 PM
  2. lx90 cresta air con condenser
    By surfingisfun in forum Tech and Conversions
    Last Post: 28-05-2010, 11:54 PM
  3. 4agze wont run properly?
    By wasfishing in forum Tech and Conversions
    Last Post: 14-11-2008, 08:31 AM
