Results 1 to 15 of 17
Thread: RA23 Fully Automated Climate Controll
    Forking Architect Grease Monkey
    Jan 2009
    S.A.
    Default RA23 Fully Automated Climate Controll
    God bless lazy engineers....
    Ill do a quick poll first, has anyone tried to upgrade the heating/cooling in their *A2*?
    Put bluntly, im going to need a custom dash to finish my GA23 project, and my heater/air con is fudged....not to mention trying to turn the demister on requires a breaker bar!
    ...and I have a fully automated climate controll system that while being slightly larger than my RA23's is in the same order of appliance (Fan, Aircon, HEater/duct controll) and even uses a couple of the same ducting placements/bolt holes
    Benefits are pretty obvious, being able to connect the unit to my dash by wires being a biggie, as well as better heating and cooling, no pushrods, and plug and play into the loom Ive already transplanted...
    Is anyone interested in me doing a writeup on this?
    Rotaries are cool...so why are their owners such cocks>>?
    Default Re: RA23 Fully Automated Climate Controll
    Yup, do it
    I had MX83 or MA70 Climate control in my RA40 for a bit. Also there is a guy on the net who did a TA22 or RA23 with one of those aftermarket A/C setups and the associated control unit that was fitted into the origonal dash, Had a quick search, but no love finding it again.
    Simon
    Beige.... The new Black!!!
    i'd certainly be one to give this a try!
    Someone donate me a climate control unit pls
    ...... butt scratcher?!
    Jan 2009
    S.A.
    lol...ill do a write up then...could be useful when the rest of your heaters etc start packing up!
    vic
    This can be done using a digital house central heating thermostat that has outputs for heat and a/c , Ie 1 controlling the heater tap and the other controlling the A/C clutch .
    There is some very nice backlit small units around .
    Most just use the 2 wire setup witch wont work . we need 6 or so wires .
    Dave
    writeups = good!
    i was thinking of transplanting the whole box and kaboodle from something like late 90's/early00's corolla or similar.... but some of those under-dash units are huge!
    Junior Member Backyard Mechanic bigmat's Avatar
    sa
    subscribe looks promissing.
    cheers mat
    The old One Backyard Mechanic
    me too (and a few more characters)
    vic
    Ive looked into doing this with many times with factory toyota setups but there far too complcated for the effort also most toyota setups just add more heat rather than control the air con clutch .
    The way the servo motors control the flaps doesnt suit the simple older
    stuff as some of the servos have 5 positions .
    EA fairmont or VN toilet may be candicates as i think there vacuume opperated servo motors move only on or off .
    If i had the time id adopt the dual zone climate out of someting new
    Dave
    Jun 2006
    EA and VN are probably a bit bulky, they are not as user friendly as jap setups, whole unit has to be removed to get at the A/C evaperator.... EA units are known to have troubles with the heater Blendor motor (opens flap for hot air)...
    I would be speaking to AC guys and finding out which late model units give no trouble and get one of those..... I wouldnt use one out of a front cut.... where would you get parts if needed?
    Breaker of all things aka Backyard Mechanic Chrisso's Avatar
    Vancouver, BC
    Subscribed. Modern in old skool!
    AE86 4 shades of silver - The Lone Ranger's steed is on the road again!
    AE86 shell - waiting for a donor car from the auctions.
    New Zealand
    Quote Originally Posted by wa5
    Someone elses front cut when they aren't looking.
    I'd personally be hesitant to use a Toyota climate control system, purely because there are so many sensors that need to be working correctly for the system to work.
    Out of the last 4 cars I've had only 1 has had a flawless system. The rest rarely do what you ask of them.
    Give me a slide control that directly actuates the heater tap any day of the week.
    Pfft, I love my climate control That said, they're quite complicated systems with a lot to go wrong.
