Brendon,
You can buy an aftermarket cable kit from Rare spares or similar shops and you can buy the cable clamping bolt for the top of your peddle.
You simply drill the top of the peddle, to take the bolt. The ball end at the carby is also available and just bolts on if the existing one is the wrong size.
Depending on what you have now you will need to make a bracket at the carby end. I will find a pic of mine when I can for you.
Otherwise I have used ST162 ones before or you can have custom cables made.
Just remember - The cable needs to be tight with the peddle on the floor - NOT tight when it's in the air. Your critical setting is WOT so you don't stretch and break cables.
