That 13.5:1 is not correct. It will be more like 8:1. Basically once you get to a high enough cylinder pressure (this pressure is dependant on the head and piston design, fuel type, fuel mixture and ignition timing and mixture temperature etc..) you can get spontaneous combustion, or detonation.
With forced induction engines since you are putting higher pressure air into the cylinder to start with, that pressure threshold is reached more quickly (once you further squish things by the compression ratio of the engine). Any engine can produce more torque and be more fuel effcient with higher compression ratios. But you can make more power with more boost, which may require a lower compresion ratio.
At the end of the day a suitable CR depends on your application and power goals.
Regards, Nick
