Hey champ ,I wired in a jzx90 tacho into my mx83 instrument cluster, as the cressida one was 12V input and the 1jz ecu was 100V (or vice versa, I can`t remember)
on the back of the jzx90 cluster, the tacho circuitry has something like (+ve),( -ve) and (signal) labelled on the circuit board.(you have to pull the cluster apart for this, but its not hard) Make sure the tacho is getting power, i.e. theres 12v going to the +ve and the -ve is grounded. then solder a wire to the signal and this should go to the signal wire of the microtech. i`m pretty sure the signal from the microtech is not the same voltage as the jzx90 tacho, but go down to jaycar and get a signal convertor and from 12V to 100V, solder it into the signal wire and if the tacho is not faulty it will work
