Results 1 to 10 of 10
Thread: MA61 temperature gauge wiring trouble after 1j conversion
    Nov 2008
    Default MA61 temperature gauge wiring trouble after 1j conversion
    Long story short. 1jzge in MA61. Temperature gauge never wired up after conversion. Wired it up yesterday and it read hot when cold. This morning when car was completely cold turned on ignition and gauge when straight to hot. Any suggestions ?
    Apr 2011
    Default Re: MA61 temperature gauge wiring trouble after 1j conversion
    gauge has to be earthed too more than likely a brown wire.
    or your sensor is screwed.
    Nov 2008
    I'm onto it.
    Act
    Wrong sensor in the engine for the guage. Perhaps you need to install a 5MGE sensor into the JZ
    Nov 2011
    it ill be the earth from temp gauge like cressy said
    Toyota earths the temp gauge back to the block
    very common for backyarders to not know this wire needs connecting
    Nov 2008
    Fixed it by running a wire straight from the temp sensor to the gauge wire in the dash. Well I didn't a mate did cause I got no idea. Big relief to finally have a working temp gauge. Thanks for your input men. Appreciated.
    Apr 2011
    sounds like there is an internal short in the harness then. if you ground the temp wire the guage will go flat out.
    if this wire is buggered, then how many more are? could be behind your auto box issues?
    Nov 2008
    cresslux I know very little about wiring, but, the wiring in the other Supra I have (5m motor stuffed) is all stock standard and looks very neat and everything works. The wiring in this converted Supra is a shit fight really and it's basically all stacked not neatly into the glovebox. There's plugs all over the place with nothing in them. Re the trans I'm not sure all the wires that are supposed to be hooked up to the trans actually are. I can start it in gear so clearly something's not hooked up. Anyway I made it more of a shit fight today by finding the old reversing lights plug and wiring a switch to it. Got reversing lights now. All I have to do is remember to flick the switch on and off.
    Apr 2011
    sounds like your car was wired by an autistic monkey.
    if it were my car, i would get the side cutters out and start again haha
    Nov 2008
    Got to use my reversing light switch last night. Bought a tear to my eye. Bottom line is I do own a pair of side cutters and I'm determined to outdo that monkey.
    By lee3671987 in forum Tech and Conversions
    Last Post: 02-05-2013, 11:08 PM
  2. MA61 - How do I troubleshoot temp gauge wiring - Solved
    By Gibbon in forum Tech and Conversions
    Last Post: 13-09-2007, 10:21 PM
