OK. . . .
Completed Confidence Test (AFR = 9 with Butane Gas) last weekend & completed hard-wiring a couple of days ago but needed a M=M DB9 connector to join cables so couldn't run engine with WBO2 connected until this evening. . .
Anyway. . .
Connected Serial Cable to ECU; turned ignition on & changed WARI "Special Functions > Secondary Serial In-Port setting to "TechEdge WBO2 2J1 as directed then saved / overwrote ECU file < attached > . . . .
I then started the engine. WBO2 LED pulsed on warm up then stayed on steady state so I figured it was working OK. . .
Problem was - the car still smelled like it was over-fuelling. . .
I went back to Wari program and under "Analogue Calibrations" tab I noticed that Oxygen Sensor Type was still set to "OEM, Narrow Band"
Am I meant to change this? If so which available alternatives are suitable?
PS: I know it might help if I created an ECU and/or Log file and posted it OR if I sent a PDF of ECU variable settings OR Live Gauges screen-shots but PDF sizes are too large for this Site and I can't post ECU or CSV files. . .
PPS: It's been a couple of years since I've done this; can anyone confirm following shortcuts? CTRL-L = Data-logging & CTRL-N = Live Gauges
George
