Originally Posted by
GeeEss
Oldskewl:
1. OEM CR was 9.4:1. Pistons are OEM but head's been machined to up CR.
2. My car ran an external MAP from Factory (not AFM). Adaptronic ECU I'm running has an internal MAP fed by separate T3 vacuum collector; which is piggybacked onto the main collector (modified OEM Fuel rail) that supplies vac. to other ancillaries like 20V ISCV, P/Steer, Brakes, Dashpot. . .
Trdee:
1. W.R.T. Pistons the guy I spoke to said that my realistic limit on 98 Octane was around 11.0:1; he generally uses Wisco.
The guy you spoke to is probably not up to speed with advancements in technology over the last decade or so then.... I have two close friends who are both running 12 or 12.5:1 on engines which are regularly street driven on 98 octane. No problems
2 I hear what you're saying about keeping my head or just plonking a Turbo on it; truth of the matter is that money isn't an issue per-se; I'm just careful how I spend it, plus I prefer the feel of a tuned NA 4AGE. . .
What I mean to say is - when you mention not wanting to piss hunned dollar bills away for pointless gains, this is what will happen if you change a head. Sure it will make a small difference, but in my opinion it is not worth the expense compared to spending that coin on some high comp pistons and fat cams instead
I passed by J&J Performance (recently rebranded as "Hyper Coating & Automotive") yesterday afternoon and spoke with a guy called James. He seemed to know his stuff but I take it John AKA "Sprinterman" no longer works at the business?
Xero may know more about this as he has had work done there before, I'll ask him to jump in to this thread
James' opinion was that I should stick to the 16V Head but switch to a Small-Port. He quoted $1500 to get it properly ported/ flowed but said for the extra $3-400 the MRP head was worth considering as the flow was verified/ guaranteed.
Again, depends on whether you think the gains are worth the 2k outlay (it will realistically be that much when you factor in miscellaneous bits to swap heads)
He said that he would retain the current 264 PonCam on the inlet but change the exhaust to a 272 to improve breathing.
Depends on your goals but for an angry-ish street motor I would go to 272s all round
He acknowledged my points about Rod/Stroke ratio w.r.t. Spool V MRP stroker kit but his preference was the BC kit (which is same/ more $$$ landed than MRP kit).
He said that (with the BC Stroker kit) an output of 130+KW at the wheels was quite attainable. . .
Xero is making over 130rwkw at 9000rpm with a stock crank, stock (prepped) rods, stock oil pump, 12.5:1 comp, ported smallport head and big cams (around 300deg). It is surprisingly docile and very easy to drive on the street. If I was building a stroker I would want to be making 150+ for the effort to be worthwhile
Bearing all this in mind I'm not that keen on dropping those kind of $$$ on a stroker kit; $3K I can live with but $5K??? You're looking down the barrel of a $10K build. . .
At the end of the day what I want is a much more responsive engine & one with enough power (170+hp @ Fly ) to be able to have a bit of fun at the odd Track Day BUT one that is ultimately OEM streetable in that;
As seen above, you dont need to go to the stroker to make this kind of power. The stroker will do it with a fatter powerband and without having to rev as hard of course, but whether that power band is worth the extra thousands of dollars to build a stroker is up to you
1. It MUST burn much cleaner* than it does now. It just runs too rich as it stands and that's after 3 Dyno tunes - I've pissed away $2K on that alone and would hate to put the thing back together & then realise I should have gone with the 20V head for cleaner breathing.
Who are you getting to tune it? One of my mates has similar power to you out of his bigport and even with a microtech as powerful as an abacus it still runs bloody well. Sounds like your tuner doesnt know what he is doing or you have some other issue with your setup
2. I don't have to turn on A/C in order to bring idle down to a reasonable level at Traffic lights.
Again, proper idle equipment (ISCV etc) and someone who knows how to tune an engine properly should make this a non-issue
3. The Rostra cruise control I installed will actually work consistently. Rostra specs claim control from 50kmh/ 30mph+ but it won't play ball below 80kmh / 50mph, even at higher revs / 4th gear.
* It is of course quite possible (probable?) that due to the too-low CR; the Tuner cannot lean out the fuel delivery any further without totally killing the low / mid range response; in which case higher compression would certainly allow more latitude in that area. . .
Unlikely, as above I think your tuner is struggling to get a decent tune done for whatever reason. The adaptronic has enough tuning resolution and a good accel pump map so this should be a non-issue. Do you have a wideband O2 sensor hooked up in the car? You are in NSW so if you like I would be more than happy to come around one day and take a look at the tune, see if there is anything immediately wrong with it etc.
In regards to Trdee's statement that the Bigport can be made to work OK with the right cams & compression.
Would I be right in saying that;
1. You cannot run as long a duration cam with the Bigport head for a given low/mid range response?
I can't say for sure but in my mind that is theoretically correct. Whether it is significant in real life is a different question though
2. Retaining the bigport head would make more sense with a Stroker due to the increased airflow?
On face value yes (bigger ports etc) but then OST has previously shown that the limiting factor in a stock bigport head is the valve size anyway, and you can always port a smallport..
PS: My mechanic agrees that for a road 16V it would have been better if I'd retained OEM induction but switching back isn't really an option as;
1. I sold all the OEM TVIS induction hardware on Ebay. . .
2. The ECU has been mapped for ITBs and I can't be arsed reverting.
GS
