Results 1 to 10 of 10
Thread: 4agze clutch
    working hard Backyard Mechanic
    Default 4agze clutch
    yo guys i am wondering if my 4agze clutch gave out will my s/c still work ,like be working all the time or will it not engage at all ...
    Default Re: 4agze clutch
    You're talking about the SC clutch? I don't think they really 'give out' as such, as in wearing out. If it did, it'd just slip, so you'd make lower boost. If the return fails, or the electronics fail, it won't engage (or maybe won't disengage)
    Are you having trouble with your SC?
    RM.
    yes, depends on the cause, if the SC relay fails and it permanently gorunds then the clutch will always be engaged, if it fails and doesn't ground it will never engaged, if the electro magnet burns out (which would probably require to be hooked up in reverse) it would never engage cause the magnet would be shot,
    if the relay is fine and the clutch is always engaged then you may have a wiring error somewhere (grounding wire), you need a + and - to power the clutch
    what mullet said about it slipping, it wouldn't slip from wearing out, the electro magnet won't ever get weaker, what wears is the metal on the plate, they have a series of spacers (washers) behind the clutch to keep it optimal distance, if this distance gets to far, the magnet won't have as much affect
    however it is very rare for the SC clutch to give out, it is usually the relay
    89' MR2 AW11... His
    00' MR2 ZZW30... Hers
    Oberst Koi-Master Backyard Mechanic
    I get a rattling/buzzing noise from mine, particularly as the engine revs drop between gear changes... almost like the cabin rattle from hell... I thought this was clutch material rattling around but i'm afraid it's a bearing somewhere in the charger.
    The noise only occurs when charger is engaged and has gotten significantly louder over the past month to the point where it doesn't sound safe to rev the engine very much.
    If you accellerate and hold foot on the brake at the same time there's a rather loud rattling/pinging type noise coming from the charger.
    Any thoughts?
    Yep, mine does that too, on lift off. Not sure what it is, it's always done it, always will (well, maybe not now that i've got a new SC14 ), but I tyhink it's part of GZE ownership. Getting louder, I haven't heard that before. Maybe the bearings are shot? Or the clutch material inside has un-bonded itself and is rattling...hmmm...
    RM.
    I'll get a recording of it after exams are finished... so sometime tues/weds.
    n.s.w
    mine makes that sound too its not that loud that i am worried though,, but yeah its at low rpm or just when i am taking off!!
    neva worried me too much though it will be replaced with a turbo soon enough
    Mine started off at low RPM, or if u buzzed the engine at idle loud charger engagement and rattling was evident...
    but over the last month i've notice that engagement/rattle noise last from 2k rpm, to 2.5k rpm, now to 3k rpm on some days... the engagement noise could then be heard during lift off between gear changes, and now finally is quiet loud, almost as if the rattling is inside the dash above the heatercore lol.
    got 2 exams tomorrow then i'll suss it all out
    Junior Member Backyard Mechanic benjamin's Avatar
    Quote Originally Posted by inertia
    Mine used to rattle because the splines on the pulley half that connects to the supercharger had worn. I used some of the Loctite metal putty and fixed that sucker(or blower) right up
    mmmmmm loctite *drools*
  1. 4agze Super Charger Clutch
    By ryguy86 in forum Tech and Conversions
    Last Post: 26-07-2007, 09:44 AM
  2. 4agze questions
    Last Post: 14-06-2006, 08:50 PM
  3. What Clutch Slave Cyl for 4AGZE with W55 ??
    Last Post: 16-05-2006, 11:33 AM
