It's pretty easy to do, but the unit from the boot is wired into the wiring harness.
Resulting in many things not working when you unplug it.
g'day!
just a question regarding the removal (or otherwise) of the EMV screen in the dash and huge control unit in the boot of my MZ21.
is there any reasons against removing said items?
what functions will i loose through removing these bits?
i want to install an all new stereo so i want as much space as possible, both in the dash and boot. i know it will probably be a fair bit of work, so is there someone out there who has performed this work on a soarer?
chris
- Silver 2012 Lexus ISF - 2UR-GSE 5 litre V8 goodness
- Black JZZ30 Soarer - 1JZ-GTE VVTi + factory R154 manual
- Blue KE17 Sprinter- 3k + K40 manual
- White MS55 Crown - 2M + 4 speed column shift manual
- Blue MS51 Crown Hard Top - Angry 4M-B + W50 manual
600 Club Member: Toymods Large Member
MegaP00 - 7MGTE Skunkworks division
RIP - Nathan Dean (TA-022)
If you remove it well all the functions that it controls you wont be able to control anymore. example: Suspension height, aircon(is this in the emv cant remember) etc.
The box in te boot (depending on what model you have) controls, touchscreen aircon and radio, and tv.
So they work if you remove it.
hmmm ok.. im pretty sure the emv doesnt control the aircon.. but if you say that unit on the boot does then ive got a problem!! idealy i dont want the unit in there, but aircon is always good in winter (the heater anyways!)
will it be ok to unplug the looms from the unit and see what each disables??
the model by the way is a 1988 MZ21 and the air suspension has been removed so there is no worries there...
chris
It only controls the aircon if you have the 87 touch screen climate control
Originally Posted by BlackSupra
I second that as i have removed the rear box and EMV screen etc from my 89` and my air-con etc works
Current Toys
97 Pajero EVOLUTION
04 Lexus ES300
92 Hilux 2wd
awesome, yeah ive read somewhere that they did a revision of the EMV and i believe mine is after thatif so then im in business!
does anyone know exactly when they changed the EMV? just so i can be sure, though i will still try to remove plugs and see what it does...
chris
