Re: Passenger Door Window Alignment Issues
I would be looking at those 2 adjusters , they have a lock nut and a flat bit for a screw driver, and even maybe loosing the reg bolts and sliding it forward
RA23? Looks very much like my TA22, and I think the doors are basically the same. From memory, you can't adjust the door window forward or backward - the lock nuts adjust the angle of the window (ie, the amount the glass leans inward. The rear quarter window is where you've got a small amount of adjustment in relation to the seal that you are having issues with (only a few mm tho). Looking at your first pic - it actually looks pretty good. Are you sure it's out of whack? The seal on my 22 is a bit different, but the door glass sits pretty close to the stainless upright - just a couple of mm of rubber showing.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
