My first thought is why do you want to do this .. I don't know where you live but if its in Australia there is no way it would pass a road worthy as playing with brakes like that is a no no unless you get it engineered & doubtfully they would pass it either ??
If you take off the Brake booster you will have to bolt a metal plate on the firewall to then mount the brake master to as there will be a fair sized hole in the firewall once you remove the booster & then you have to try & work out a suitable linkage rod to the brake master cylinder as you wont be able to use the brake booster one or not without altering / lengthening it, I'm assuming the KE30 doesn't run a booster you could use that link rod maybe ?? ..
Running a smaller master cylinder will help the pedal effort as you have removed the booster but it may still not be enough & the pedal still could be quite hard to push ?? ( apply the brakes hard ) if you go to small in the Master cylinder you will have increased pedal travel though ..
				 Using a smaller MC in KE70 after removing brake booster
