Hey,
having a bit of trouble finding the mysterious leak
left my car out one night, came back to it with the entire passenger side with a nice pool.
it seems to run down the left side and misses the glove box, but lands on the parcel shelf beneath it
i thought it was caused by the front vent being blocked from letting water run down the outside and thus going in through the air vent
so I've cleaned inside the vent ran water down and no leak inside.
the windscreen weather seal it solid, the panels are straight.
any ideas?
1972 TA22 2t-g blue beautiful runs like a bitch need as much help as possible
The original radio antennae grommet sits above the level of the parcel shelf, and as water sheds from the plenum chamber it runs right over this grommet. If the grommet is stuffed or missing there's your leak.
To determine where a vehicle is leaking panel beaters will spray an emulsion of talcum powder and metho over every seal and in all the areas where a leak could occur, the meth evaporates and you leave a coating of talcum powder behind. Shut all door and widows and drown the car in water, walk away for 10-15 minutes for the excess water to drain, then go back and see where the water has washed the talcum powder off..
cheers Chuck.
MS51Crown Coupe,
