In regards to the 2zz suggestion,
if memory serves the mounting positions for the engine mounts are wack due to its fwd mounting layout therefore making it an expensive option to convert. Keep in mind this is remembering way back so if I'm way off forgive me. Also the inherant cost involved with engine purchase as well as a custom ecu thats capable of running the vvti, because of the linked key to ecu link, the stock ecu is not an option unless the original key, transponder can be found.
3sgte is gunna be the ultimate choice as long as it takes, for smoothness, out of the box reliability and power and weight balance. The initial bitchiness of this conversion will be far outweighed by the advatages of such a setup.
Hope it helps and good luck.
