Battery boxes come with mounting straps that screw to the boot floor, pretty simple. I use truck battery cable as it is double insulated and meant for external use. I then wrap it in split conduit and tape it and run it under the car along the chassis rail with P clips. It is desirable to run a full length earth cable but not totally necessary.
Secure, clean earth points are obviously essential though.
I use a junction post at the std battery location to distribute power from the main battery cable to the starter cable and main vehicle power supply. This maintains the factory power feed layout and avoids voltage drop problems during cranking that MAY occur if the cable is mounted straight to the starter. Aftermarket ecu's are particularly susceptible to this problem.
I use DIN batteries in the boot as they are sealed and designed for use inside European cars. They are also built to higher std's than std batteries as they are for cold climate use. A DIN 66(mid way between normal large battery and N70 monster) is about $120.
Whooosh!!
