Results 1 to 15 of 24
Thread: Ova Heatin Problem!!!
    Angry Ova Heatin Problem!!!
    I have just installed a new water pump and reconditioned my radiator, but its still over heating big time.
    And also its spicking heaps too......
    Would like some HUGE help!
    And the cars a ST185 Celica GT4 3SGTE.
    1990 Toyota Celica GT4
    POD Filter, 3" Dump Pimp, 3" Exhaust System with Cat, FMIC, Turbosmart In-car Dual Boost Controller 9psi running, 15psi switch, looking at more to come
    Western Aus
    Default Re: Ova Heatin Problem!!!
    Quote Originally Posted by ST185 Celica
    huh?
    when you replaced the water pump, was the block and head flushed?
    also, when it overheats, is it a constant thing, or does it only happen when stationary for a period of time?
    im assuming thermostat was replaced, as any reputable place wouldnt think of putting old things back in...?
    Eldar.O.
    yeh forgot bout that haha yes a new thermostat was put in.
    The whole block was flushed and not just once either
    what about the old head gasket problem? if you can with out over heating it to much (witch might lead to warping if your not carful) try and get it to you nearest natrad....they do a free cooling system check.
    Carless Grease Monkey
    VIc
    get a teekay and compression test. Overheating either points to water pump , thermostat, blockage, And finally headgaskit problem. As you have changed the rest you are only left with one option. If it was a 7M than it would have been only BHG.
    Lets hope it is fine.
    yeh i did the comprision test and it was all fine on 20psi...
    so other wise itll either be a head or blockage...
    How much would it cost to get the head reconed and who would be good to do it (company)???
    i hope that was a mistype? 120psi?
    Going back to basics here, it *IS* actually over heating isn't it? its not just the gauge lying to you?
    when you re-filled the coolant system you bled it up really good? i seem to remember GT4's being a bit funny about that?
    you haven't put in new thermo fans or anything like that recently?
    as the other guy asked, does it cook just driving along? or in traffic? or?
    crack in head or head gasket!
    Quote Originally Posted by SL666
    Yeah, i too remember a discussion on bleeding the cooling system of 3SGTEs. Cant remember the resultant bleed method, but if you search the old forums, you should be able to find it.
    forums.toymods.org.au for those more forgetful.
    Welcome to the Darkside! Automotive Encyclopaedia -==L=a=N=c=E==-'s Avatar
    Rosewood
    GT4's don't have anything techinical about bleeding them. MR2's on the other hand do.
    Easiest way to bleed it. Have the noise of the car sitting high, and start the car and warm it up, and top up the coolant as the bubbles rise outta the cooling system.
    also a good way of see if if its a BHG. The Nose knows. *sniff sniff*
    Gen2 3S-GTE's are reknowned for blown head gaskets, especially if pushing more then factory boost.
    how would that cause overheating?
    has no Toyota anymore :( Conversion King tooch's Avatar
    I think its common for 3SGTE's to get airlocks in the heater core hoses, you can just pull off the one going into the bottom of the tap, start the engine and wait until coolant pisses out, then put it back on.
    you should be able to just run with the heater on and the air will bleed out of the system.
    the thermostat wasnt put back in the wrong way was it?
    if you have a bad air-lock in the heater hoses (some cars have very convolouted systems) you sometimes can't get enough pressure on one side of the heater to clear a blockage without driving the car..
    serial biochemist Automotive Encyclopaedia
    if the head is cracked you will see bubbles when you look in your radiator.
    Start the engine from cold with the radiator cap off. Watch the coolant in your radiator until it either starts swirling or bubbling.
    swirling = good
    bubbling = bad
    if the head is bad you may also see oil in your coolant (floats on top of the coolant) and if it's really bad then the coolant will literally blow out of the radiator. But I don't think that's going on for you.
    Are you sure all the hoses went on right when you flushed the rad and re-installed everything? You could simple have bypassed/blocked something accidently.
    your rep rating is not a reflection of your worth to the community
    Quote Originally Posted by H1TMAN
    wtf? I want to do track racing, and f#@k you...
    that's very flattering but no thanks.
  1. TPS Problem
    Last Post: 28-04-2006, 03:10 PM
  2. Oil mist, cam cover problem
    By BoostBoy in forum Tech and Conversions
    Last Post: 28-02-2006, 08:53 PM
