Buy my 3rz its forsale![]()
Ok so this all started with wanting to have a largish engine in a smallish car (ae86) the biggest you can fit capacity wise in turbo form is around 2500cc and i wasnt about to jam a 1jz into it as i still want it to handle.
It was always going to be a toyota engine and there isnt much choice if your're a tight arse like me soooo.... I'm building a 2RZFTE, the 'mericans seem to go pretty well with these in their tacoma's and can take just as much thrashing as a 3RZ so that's what i'm doing.
Problem is we never got the 2RZFE here just the 2RZE but here is where it get's interesting, parts are very similar between model's;
2RZE block = 2RZFE block
2RZE crank = 2RZFE crank
2RZE rods = 2RZFE rods
2RZFE head = 3RZFE head
2RZFE headgasket = 3RZFE headgasket
2RZE timing case = 2RZFE,3RZFE timing case
I have to get 2RZFE pistons but thats about it
Goal power wise is a mild 350HP, turbo choice is still undecided but something that would boost hard between 2500-6000rpm......
more to come.
Destroyer of 'Drop Forged' spanners
RA23 - Twincharged
JZZ20 - Daily
2.7 = no go in QLD......sucks because i would have bought your setup![]()
ok so update time,
i just got the block back from being cleaned, its not getting anymore machine work until i figure out a few more things.
host image
next up is the sump i got from the u.s. its from a usa only T100 tacoma that uses the 2rzfe motor, the only rz engine with a proper front sump to suit corolla's etc
part numbers are visible if you need them
print screen windows 7
oil pick up and dipstick/tube.... i also have to get a new front timing cover but thats easy to get as the prados over here have the correct version (dipstick goes through timing cover not side of block)
image hoster
the biggest problem i now have is the R150 i was going to use suits a 3rz block...which is taller so wont fit the shorter 2rz block, poo. so its either back to a w series box or trying to find a bellhousing to suit?......
i do have an adaptor plate that goes from R150 to a340 series auto bellhousing, problem is the 1rz/2rz engine's only came with a44d autos...dammit!!
image hoster
the next problem is the R150 not fitting the block as it suits 3rz blocks which are taller....der........
how to screen capture
