its prob a manual ecu ,
if its an auto ecu what style plugs does it have,
really early 1js I think jzx80 81 not sure as I havnt wired one in ages you had to make sure speed signals where right otherwise it would stay in first
did you buy the car knowing this problem was there or was it working ok and now it has failed as most 1js have the output shaft speedo sensor SP2+ SP2- already hooked up
in the original wiring and this wiring does not need to be hooked up so either wiring is wrong or speed sensor is faulty
