just get an early 3uz much less hassles with everything unless u have shitloads of dollars to fix and sort out the fiddly bits
the security is easy to sort out if its old school key chip and reader
it only gets complicated when its the smart key which in aussie Toyotas only came in after 07 08 ish in 200 series landcruisers
so basically anything with key button start will prob have smart key which means u need 4 ecus to talk and link up before engine will start
most cars with a normal key in ignition can be worked out by flashing the immobiliser chip if you have no keys
why not just put an ls3 with a 6 spd auto in an is200
fits in nicely and would go much better and probably cost the same hehehe
