Results 1 to 15 of 18
Thread: 1GGTE cam seals
    Junior Member Grease Monkey amon's Avatar
    NT
    Default 1GGTE cam seals
    Would toyota be the best bet for these ones?do they share a common seal with an aussie toyota?
    any hints
    cheers Guy
    south australia
    Default Re: 1GGTE cam seals
    i would just go to toyota to get a price. if they are pretty good then go ahead and get them.
    you can try ringing round to a few other places to get an idea if anyone has any. might be hard to come by tho. i bought a genuine gasket set and it was well priced and was a good product. i recommend toyota this time
    Junior Member Grease Monkey BigBadBenny's Avatar
    Guy,
    Personally I do use genuine seals seals in motors, but being an import, they may not have a listing, If you've still got the old seals, get the numbers off them and then go to any bearing or seal shop and your out of trouble.
    SKF has never let me down, oh and if there are no numbers, then take the seal with you o they can measure it for you, or you can do it yourself, inner and outer diametre and depth.
    All too easy
    Regards
    Benny
    I got mine from Toyota, they cost (if I recall correctly) around $25 each or less (may have been like $15) Can't recall 100%
    Part Numbers
    Cam Seal - 90311-35040
    Front Main - 90311-45015
    Rear Main - 90311-75009
    Hope this helps
    Simon
    Beige.... The new Black!!!
    NT
    Thanks everyone for the rapid response,Castle Hill toyota it is.
    Cheers Guy
    Junior Member Domestic Engineer 1200det's Avatar
    The following are the part numbers for the 1G Series
    Cam seals 90311 - 35022
    Rear Main 90311 - 75007
    ### The part numbers that Lambolica mentioned may also fit the 1G series although there listed part numbers for 2E 3E Series engines.
    Current Toys
    97 Pajero EVOLUTION
    04 Lexus ES300
    92 Hilux 2wd
    Take the seals out and get them matched at a bearing shop. Toyota do charge like $25 each for them, but I paid $3 each, because they are a NOK seal that Toyota will give you anyway.
    Same deal for the rear main seal. Cost me about $20-25 to get it matched, whereas the Toyota price was something stupid.
    Quote Originally Posted by JustCallMeFrank
    to add to his! CBC bearings have the seals you want! just take you old one and match it up. i do it all the time. just be gently putting them in so you dont catch an edge or push it in to far!
    CBC I found were usually more expensive though, and one of their seals they gave me for my rear main was weird and I couldn't get it to seal properly.
    like everyone else said, dont touch toyota with a 10' barge pole
    just take to your local bearing shop and theyll measure and pull you down what you need off the shelf
    beenleigh bearings did mine for a fiver each, and the rear main for 20
    Ive got all these seals Genuine Toyota
    $100 neat and ill post em to you.
    Retail Toyota :
    Cam Seals $17 Each X 2
    Rear Main $69.90
    Front Main $27.30
    If you interested let me know
    Current Toys
    97 Pajero EVOLUTION
    04 Lexus ES300
    92 Hilux 2wd
    If you were after just the Cam Seals
    $30 posted.
    Current Toys
    97 Pajero EVOLUTION
    04 Lexus ES300
    92 Hilux 2wd
    NT
    Thanks lads my local Toyota dealer had them for $32 for the pair.
    again thanks for the responses
    Cheers Guy
    Out of curiosity what are the part numbers you got??
    I stand corrected if I'm wrong But those are what I got. I'd like to know so I can retract my other post before people order based on that...
    Quote Originally Posted by Lambolica
    Lambolica , I would assume those part numbers you have could well be correct as a superseeded part number to what i have posted.
    But yeah would be nice to see what Toyota Australia have supplied
    Current Toys
    97 Pajero EVOLUTION
    04 Lexus ES300
    92 Hilux 2wd
  1. 1GGTE into RA65 Questions.
    Last Post: 20-11-2006, 08:51 PM
  2. 1GGZE SC on a 1GGTE?
    Last Post: 22-06-2006, 08:15 PM
  3. 18R Valve Stem Seals - Replacing Q's
    Last Post: 03-02-2006, 01:50 PM
