Results 1 to 15 of 20
Thread: 1988 Century. A340E need speedo sender unit and/or advice
    Feb 2014
    Default 1988 Century. A340E need speedo sender unit and/or advice
    Hi, the speedo sender in my Century has a dodgy earth (worked on and off - now off!) Has anyone who has owned/wrecked one got a spare?! Long shot I know.
    Have tried a similar unit from a early 90s Cressida with no joy.
    Does anyone have thoughts on whether a Crown Royal with the digital speedo display could use something that would work despite the obviously different transmission. With the dual aircon and fridge unit etc, I thought there might be some possiblility of a win.
    Default Re: 1988 Century. A340E need speedo sender unit and/or advice
    I'm pretty sure the UZS131 Crown uses that exact sensor.
    Feb 2014
    Thanks very much! Unless anyone reading this has one, I will get on the phone. Cheers!
    Nov 2011
    They are a 20 pulse sensor
    I know u can get an aftermarket 16 pulse sensor
    But I've never found an aftermarket 20 pulse one
    As a last resort u can use a 16 pulse then fit a speedo correction box
    To make the speedo accurate again
    Junior Member Conversion King
    May 2010
    I hope I'm looking in the right spot, but here goes.
    Toyodiy brings up two versions of the speed sensor for VG40 Century (both floor and column shift use them):
    89411-22060 (09/1987 - 11/1988)
    89411-22061 (12/1988 - 11/1992)
    Apparently there's a rotor that sits on top of it as well? Could be this that's worn and needs replacing?
    89414-30020 (09/1987 - 11/1988)
    89414-30021 (12/1988 - 11/1992)
    Cross referencing the earlier part (sensor and rotor), they are used on:
    02/1986-07/1988 TOYOTA SUPRA GA70,MA70
    08/1988-04/1993 TOYOTA SUPRA GA70,JZA70,MA70
    08/1984-07/1988 TOYOTA MARK 2 GX7*,LX7*,MX71,SX70,YX7*
    08/1988-11/1995 TOYOTA MARK 2 GX81,LX80,MX83,SX80,YX80,JZX81
    08/1984-07/1988 TOYOTA CHASER GX71,LX70,MX71,SX70,YX7*
    08/1988-09/1992 TOYOTA CHASER GX81,LX80,MX83,SX80,YX80,JZX81
    08/1984-07/1988 TOYOTA CRESTA GX71,LX70,MX71,SX70
    08/1988-09/1992 TOYOTA CRESTA GX81,LX80,MX83,SX80,YX80,JZX81
    02/1981-11/1985 TOYOTA SOARER GZ10,MZ1*
    01/1986-12/1987 TOYOTA SOARER GZ20,MZ2*
    01/1988-03/1991 TOYOTA SOARER GZ20,MZ2*
    08/1983-07/1987 TOYOTA CROWN GS12*,LS12*,MS12*,YS120
    09/1987-09/1991 TOYOTA CROWN GS13*,LS13*,MS13*,YS130,UZS131,JZS13*
    09/1987-12/1996 TOYOTA CENTURY VG4*
    Cross referencing the later model part:
    05/1990-11/1999 TOYOTA ESTIMA TCR1*,2*
    08/1989-12/2004 TOYOTA HIACE, REGIUSACE KZH1**,LH1**,RZH1**,TRH1**
    04/1997-04/2002 TOYOTA HIACE TOURING, REGIUSACE KCH4*,LXH4*,RCH4*
    08/1995-12/2004 TOYOTA GRAND HIACE, GRANVIA KCH1*,RCH11,VCH1*,2*
    Plug those part numbers into Amayama.com and away you go.
    Feb 2014
    Thanks for your help guys. Mine is right on the changeover date!
    Let you know how I go. Much appreciated.
    Feb 2014
    You wouldn't happen to know the whereabouts of such an item?
    Feb 2014
    Quote Originally Posted by Century88 View Post
    Nov 2011
    I just had a look in my junk bin and I got one of an old crown
    the plug is only an inch away from the sensor and going by yr pics yrs might be longer
    anyway 50 bucks for the sensor without the drive pin
    or 60 bucks for sensor with a brand new drive pin
    Feb 2014
    Is there any chance you could post a pic?
    Nov 2011
    ill get a pic this arvo as I have to drop off kids at school then go to work
    Feb 2014
    No worries, I know that routine...
    Nov 2011
    is this ok
    Feb 2014
    I guess it's just a case of adapting the cables to join with a new connector - otherwise it looks fine. Gotta be worth a shot. How shall we sort it?
    Nov 2011
    ill just COD it if u want
  1. Electrical sender unit for w58
    By RAd28 in forum Tech and Conversions
    Last Post: 17-01-2006, 05:24 PM
