Hi Callum,
Should you chose to stick with the draw through setup I would actually suggest you do your upgrades one at a time. Start with a nasty clutch capable of handling 400hp as future proofing.
From there work out the tune & wind up the boost carefully & observe the results closely. Spark plug tips being damaged or gaining miniature metalic balls tell of detonation. Once you simply blaze the tires any time you go to play then it is dyno time for more development. Turbo & waste gate replacement would follow once the originals are delivering no more gains.
Efi gear for these babies is still available if you keep an eye out particularly overseas. Then any reputable tuner can give you results if you prefer someone else to tweak your ride.
Jason
