Results 1 to 12 of 12
Thread: FWD Corolla's and final drives.
    Beer anyone?? Domestic Engineer Just1n_mc's Avatar
    Dec 2006
    Default FWD Corolla's and final drives.
    I currently have a C56 gearbox in my AE82 Racecar but after running it at Phillip Island I noticed I was hitting the speed cut (180kmh which has since been bypassed) in fourth about halfway down the straight. I still had rpm left in fourth but it made me realise that even if I did get into 5th gear it would of only been for a very short time and that I probably could make use of a shorter final drive to make better use of the gearbox.
    I've tracked down a supplier of 4.75 and 5.15 final drives that I can get for a reasonable price but I was hoping someone had swapped one out and could give me some feedback before I decide which way to go.
    I've worked out that the 4.75 will run out of revs (8,200) in 5th at 230km/hr and that the 5.15 will be at 212km/hr. Having hit 180 half way down the straight in 4th with the standard final drive I'm concerned that I'll run out if rpm if I use the 5.15 at Phillip Island. I haven't tried the car at Sandown yet so I'm not sure how long the back straight is there.
    1970 2M MS55 Crown - Weekend Cruiser.
    1970 2R RT40 Corona - Cruising Grandpa Style
    1986 20V 4AGE AE82 Corolla - The Brown Racecar.
    1988 4AGE AW11 MR2 - Sold but not forgotten
    1992 1MZFE SW20 MR2 - Sold Supercharged V6 Monster.
    Dec 2006
    Default Re: FWD Corolla's and final drives.
    Anyone played with final drives at all?
    Jul 2007
    i have no experience with final drives beyond stock offerings for C and E series boxes but i do have some experience with going fast you will hit an aero wall at around 180 and i think you will find that picking up much speed beyond that will be quite a challenge if you are running an n/a 4A (are you?)
    you would probably be best off asking someone like bway who has raced an AE82 at PI before for better feedback.
    Dec 2006
    Yeah I was at Phillip Island two weeks ago and with the speed cut disabled I topped out at approx 210km down the straight so aero is definitely an issue especially in the aero challenged AE82.
    I've got a worked head and cams to go in shortly so im hoping I can squeeze some more out of it.
    A cheap TRD final drive has fallen into my lap if I want it so I'm still toying with the idea but was hoping someone had some experience they could share with me.
    Dec 2006
    I've currently got a silvertop putting out 102kw at the wheels.
    Oct 2009
    I doubt you would hit more that 212km/h on the straight, go for the 5.12
    Jul 2009
    Go 6 speed.
    Dec 2006
    I Plan to stick with the 5 speed.
    Have heard from a few people that the C160's don't stand up to too much punishment.
    Oct 2009
    Same casing and gear size as a C52/C56 with an extra gear;
    They are not rated for massive torque but like most Toyota gearbags, lots of margin.
    Dont forget that the 2ZZGE came with a C series 6 speed so if it will handle that in a porky FWD then I cant see a worked 4A being any risk - its not like your going to ever make big torque with 1600cc NA.
    People say the same about W58's, apparently there is one version out there with a steel section that is the bees knees but I'll guarantee that wont save 3rd when it strips etc
    Jul 2009
    Quote Originally Posted by Just1n_mc View Post
    Don't use a C160, use a C60 gearset inside C52/C56 gearbox case, drop in a ZZW30 factory LSD and you have a killer little NA gearbox for a 20V.
    Seen them take plenty of abuse behind a 4AGZE without failure.
    Aug 2013
    Quebec, Canada
    Quote Originally Posted by dnegative View Post
    That would be a C60 found behind 2ZZs.... the C160 has the same gear thickness has the little C15x box behind 1.3 and 1.5L N/A toyota... not even able to hold down the torque of a stock 4E-FTE. Final drive gear is also a lot skinnier than on the C52/56/60.
    KE20 1974 <- Sold -> Thread
    AE95 1990 <- 4A-GZE daily driven wagon...
    Jul 2007
    C160 is used on 6spd blacktop 4As from factory. No real issues. A worked silvertop wouldnt make significantly more power to worry one...
    but yeah a C60 swap with helical diff is also a nice solution no doubt. probably easier than sourcing a c160 these days anyway
