Results 46 to 50 of 50
Thread: URGENT: anyone good with megasquirt? Tried everything
  1. #46
    Default Re: URGENT: anyone good with megasquirt? Tried everything
    what are you using for accel?
    TPS/s or MAP/s?
    you can also reduce the length of time of the fuel pulse, as well as pulse width, to reduce total amount of fuel chucked in
  2. #47
    Junior Member Backyard Mechanic Ashh's Avatar
    Nov 2012
    I was using TPS/s
    the problem with the fuel pulse/pulse width was at 0.1s (which was the lowest it seemed to be able to go, it would go rich, but at 0s it would go lean...
  3. #48
    Tps/s accell only good for ITBs or similar setup where there's very little manifold volume after the throttle plate. Stick with MAP-based accell enrichment.
    Also, leave accell tuning alone until you have the fuel map sorted.
  4. #49
    0.1s, but what was the PW % enrichment? can wind that right back too
  5. #50
    Nov 2012
    Cheers! I will give it a crack. To be honest I haven't played with it since the first hour and a half street tune. I'll switch it back to MAP.
  1. 4AG Silver Top with Megasquirt
    By kikin3t in forum Tech and Conversions
    Last Post: 29-07-2008, 03:36 PM
